Transformer hypothetical question
Discussion in 'General Electronics Chat' started by Zatnikitelman, Oct 3, 2006.
  1. Zatnikitelman
    Thread Starter Active Member
    Jul 17, 2005
    31
    Just for quick reference, what would the effect be if a transformer's secondary and primary windings had the same number of turns? This might be ablittle vague, so let's say 12v AC supplying 12 Amps at 60Hz or 12v DC supplying 12 amps.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Isolation transformers have the same number of turns in the primary and secondary. The output is the same as the input, but with no ground reference.
    Your illustration is hard to follow - transformers work on AC, not DC.
  3. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    thats a 1:1 ratio, which gives you the same AC volts out as in.... BUT the current is a function of the Core size and wire gauge.
  4. Zatnikitelman
    Jul 17, 2005
    31
    Ok, thanks. But I thought tranformers worked with DC as well as AC. How does DC get stepped up and down then?
  5. Zatnikitelman
    Jul 17, 2005
    31
  6. Gadget
    Jan 10, 2006
    613
    Generally it is converted to AC first, put thru a transformer, then converted back to DC at the other end..(normal with stepping up, not so common with stepping down).
    If its just a small step down, then the DC can just be divided/series passed/shunt passed.
