Transformer Humming/VIbrating
Discussion in 'General Electronics Chat' started by lubnaan90, Mar 29, 2010.
  1. lubnaan90
    Thread Starter Active Member
    Jan 13, 2010
    196
    I have recently repaired an old soviet Amplifier, which uses a High power transformer.
    The transformer seems to be making a Humming sound , which i should say is very annoying, the Humming sound & vibration is not loud though, but an irritating one.
    Any advises or recommendations to get rid of this problem will be deeply appreciated.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This can happen with E-type laminated cores. Here in the USA, they used to use a shellac as a sort of an adhesive to keep the laminations in place. It may be that the material used in your transformer has aged and cracked, so the laminations can once again vibrate against each other, making a humming or buzzing noise.
    I do not know what type of material to recommend that you use, as I have no idea as to what you may have access to in the Ukraine.
    Lacquer would not be a good choice, as it may dissolve the insulation on your windings, which would destroy the transformer.
    lubnaan90 likes this.
  3. lubnaan90
    Jan 13, 2010
    196
    Thank you for your quick response.
    Understood, So this means that the PSU is fine , no problem with the rectifier or other capacitors, its just the adhesive which might have aged. Is it ok if i continue using the transformer in its current (humming) status ?
  4. Mike33
    Feb 4, 2005
    349
    25
    Depending on your skill level, I would consider opening it up, and lightly driving (pressing) some very small wooden shims between the windings and the core. That is what they do when they re-wind transformers and the new winding is too small. It's just vibration, but could possibly lead to wear and shorting in the future, in my opinion.
    Post a photo if you can, so we can see how you would take the bell covers off (if possible).
    Another idea is to "pot" it in wax, but you'd have to know how hot that trafo will get, and whether the wax will stay solid at the operating temperature...I'd go for shims.
  5. creakndale
    Mar 13, 2009
    68
    7
    I have an older Yamaha amplifier that began transformer buzzing a few years ago. The problem appeared to be deteriorating shellac as the Sgt. mentioned. I cut various shapes of mylar (plastic sheet) and wedged them inside the transformer to minimize the vibration. The buzzing was greatly reduced though not completely eliminated.
    creakndale
  6. lubnaan90
    Jan 13, 2010
    196
    Thank you for your useful quote.
    I have attached a picture of the transformer with this reply, please check the same.
    I would also prefer using the "Shims" method, as i think "Potting" the transformer in wax will be a risk taking factor for me.
  7. creakndale
    Mar 13, 2009
    68
    7
    While it's operating and buzzing, use a wooden stick (popsicle stick) to push on all the pieces that make up the transformer assembly. When you find a spot where the buzzing volume increases and decreases with applied pressure, that's where you want to add a shim.
    Make sure all the screws that hold the transformer assembly to the chassis are tight.
    At worse case, you might need to unscrew the transformer assembly from the chassis and add some dampening material between the transformer plate and the chassis.
    creakndale
  8. flat5
    Nov 13, 2008
    403
    17
    First easy fix is to just tighten all the bolts.
    It sometimes makes a difference.
  9. lubnaan90
    Jan 13, 2010
    196
    Thank you ,
    will work on it & update.
  10. lubnaan90
    Jan 13, 2010
    196
    Sure will start with bolts first, if still the humming/vibrating continues , then will proceed using "Shims" method.
  11. t06afre
    May 11, 2009
    5,939
    1,222
    For many (many) years ago I salvage a big transformer from some computer equipment. I remember it had a big 250uF high voltage cap (ca 400 v) connected to it. Without this capacitor the transformer was humming and vibrated more than expected. It was also getting somewhat hot. But with the capacitor everything was as normal. I do not know how this capacitor was connected to the transformer. But perhaps you need something like this, and that other members can explain why and how.
  12. lubnaan90
    Jan 13, 2010
    196
    Thanks a lot for your quote,
    In fact i myself was planing to change the Capacitors & the rectifier in the PSU.
    Now after your quote i will do that in the first place.
  13. Mike33
    Feb 4, 2005
    349
    25
    Be careful, but this should be pretty easily correctable. :eek:)
  14. lubnaan90
    Jan 13, 2010
    196
    Changed all the 2200uf capacitors & the rectifier chip in the PSU, the humming sound has considerably reduced.
