Q. If I have an AC power source of 100 volts at an odd hertz of something like 250 Hz is there any reason why I cannot build a transformer with this input on the primary and 14 VAC on the secondary? I would be using a salvaged core from an old transformer to wind new transformer wire after stripping the old winding from the used core.
This 14 VAC would then be rectified to DC to be used to charge a battery bank.
The only transformer information I have seen has to do with either 50, 60 or 400 Hz. Is there some reason why only these frequencies are mentioned other than they are the standard ones used by countries or military? Is there some sort of electrical "rule" that would prevent the project above?
Mac
Mac
