Transformer help
Discussion in 'General Electronics Chat' started by Chillum, Dec 7, 2014.
  1. Chillum
    Thread Starter Active Member
    Nov 13, 2014
    546
    9
    I need help choosing a transformer, the one that I'm looking at is "Toroidal Transformer, 160VA 0-35/0-35 "
    Is that 35v 4.5A?
    I have a stepdown circuit with input voltage no bigger that 37V, will this transformer exceed 37v
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    An 160 VA transformer of dual 35 Volts will have a current rating of about 2.25 A on each 35 Volts output.
    Bertus
  3. Chillum
    Nov 13, 2014
    546
    9
    and more amps with lower output? how much heat will it generate?
  4. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    No, you can not draw more than 2.25 Ampere on each output.
    If you draw more current, you will burn your transformer.
    Bertus
  5. Chillum
    Nov 13, 2014
    546
    9
    how easy is it to build a current limiter? (and the heat question?)
    oh and won't lower voltages pull less current then
  6. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    It is very easy to modify a toroidal transformer, either by taking turns off, adding turns or simply adding a small secondary if needed.
    In the case of the double pair windings, they are usually wound bi-filar which allows removing/reducing both windings at the same time, if needed.
    Approx: 2 turns/volt.
    Max.
  7. ISB123
    May 21, 2014
    1,240
    531
    You can use LM3xx to build current regulator.It will require heatsinks.
    After rectification and capacitors you will have 50V at the output.
  8. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Modifiying for lower voltage = higher possible current up to the Va rating.
    What voltage are you aiming for?
    Max.
  9. Chillum
    Nov 13, 2014
    546
    9
  10. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    After rectification and smoothing 30v = 42vdc (30ac x 1.414).
    As I mentioned it is comparatively easy to modify a toroidal, I have customized many in the past.
    For 37vdc a 26vac is required.
    Max.
  11. BReeves
    Member
    Nov 24, 2012
    412
    64
  12. Chillum
    Nov 13, 2014
    546
    9
    I'm wary of adjusting a R600 device. Not only does that power supply exceed my budget by about ZAR200, shipping is going to add another ZAR200-300, so no, not an option
    the cheaper one is withing my budget, but probably not after shipping
    FOUND IT:
    http://www.mantech.co.za/ProductInfo.aspx?Item=372M0368
    350 WATT SINGLE OUTPUT ENCLOSED SWITCHING POWER SUPPLY
    INPUT: 90-132VAC / 180-264VAC OUTPUT: 36VDC @ 9.7A
  13. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    The advantage of a linear supply is it tends to be a alot more rugged and in the event it caves in it can be fixed relatively easily.
    This if you do not really need a tight regulated supply.
    Max.
  14. Chillum
    Nov 13, 2014
    546
    9
    ok , well other than being a switching supply, it's in my price range, it handles high amperage, it's got built in short/overload prrotection, which I can't build because heatsinks (other than cpu heatsinks) doesn't exist in cape town, so unless the switching part is really a problem, this is the power supply for me. your comments/advice please?
  15. ISB123
    May 21, 2014
    1,240
    531
    You are still going to need to adjust the voltage since its single voltage PSU.
  16. Chillum
    Nov 13, 2014
    546
    9
    but can't I use the switching power supply we built in wattage in resistor devider thread?
  17. ISB123
    May 21, 2014
    1,240
    531
    You can but with 30k pot.
  18. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    If the load varies at all significantly, NO.
    No regulation and a power waster.
    Max.
  19. Chillum
    Nov 13, 2014
    546
    9
    I don't know yet what my applications will be, but with the lack of heatsinks can you suggest a better solution?
  20. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Why do you need to drop the voltage if the power supply has the output you need?
    Max.
