transformer help required
Discussion in 'Electronics Resources' started by samseed, Feb 11, 2009.
  1. samseed
    Feb 11, 2009
    hello, i have a small transformer which has the specs label missing off the top. can it still be identyfied??.. any help,suggestions greatlly appreciated..cheers....sam
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    I can only see two wires.
    The bottom chamber seems to be empty.
    Is there a picture from the other side ?
    With only two connections it can be used as a choke.
    Greetings,
    Bertus
  3. samseed
    Feb 11, 2009
    I thought it was a transformer.Thanks for clearing that up.yes it only has 2 black wires,and bottom chamber is empty.. Is it just a simple choke or any other name its called by..Meny kind thanks..sam
  4. mik3
    Feb 4, 2008
    4,846
    63
    It looks like the primary winding is missing!!
  5. samseed
    Feb 11, 2009
    i took it apart to see what i could learn and then binned it,,thanks guys..sam
  6. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    If you want to know more on transformers take a look at this page of the EDUCIPEDIA.
    http://www.educypedia.be/electronics/electricitytransformers.htm
    Other components have also pages over there.
    Passive semiconductors technology: Batteries Diodes Photovoltaic systems Switches Buzzers Diode types Quartz crystals Thermoelectric Capacitors General overview Relays Transformers Capacitor types Heat Sinks Resistors Transformers-RF Coils Photo diode Resistors-Nonlinear Transformer types
    Greetings,
    Bertus
  7. samseed
    Feb 11, 2009
    Thank you sir for the link
  8. rxtxau
    Dec 13, 2003
    That type of transformer is specially sold in that format in a variety of VA ratings to allow you to wind your own windings onto it. The mains winding is prewound for convenience & to meet electrical safety requirements.
    Regards,
    Brian.
