Transformer help please
Discussion in 'Homework Help' started by elecstudent, Nov 17, 2011.
  1. elecstudent
    Nov 11, 2010
    26
    This is the questions that I have been given;
    1a) A 4 pole synchronous motor rotates at 3000 RPM. The torque on the motor is 20Nm and the efficiency is 90%. What is the frequency of the electrical supply? (Hz)
    1b)
    What is the load on the electrical supply? (Watts)
    Can anyone help to start me off?
  2. crutschow
    Mar 14, 2008
    13,469
    3,356
    There is a direct relationship between motor speed, the number of poles, and the supply frequency. Google synchronous motors and you will find that equation.
    The power generated by the motor is torgue times RPM. From that and the motor efficiency you can determine the motor input power.
  3. elecstudent
    Nov 11, 2010
    26
    I calculated question one to be 100..
    am I right?
  4. crutschow
    Mar 14, 2008
    13,469
    3,356
    That is correct.
  5. elecstudent
    Nov 11, 2010
    26
    using this formula (if it's the correct 1)
    HP = rpm x T(torque)
    5252(constant)
    I got;
    11.9HP = 8519W
    Is this correct? as the W value looks huge..
  6. elecstudent
    Nov 11, 2010
    26
    anyone? a bit of advice please would be appreciated
  7. crutschow
    Mar 14, 2008
    13,469
    3,356
    I believe your constant is not correct. That looks like the constant for conversion of torque in lb-ft to HP, not Nm.
    So you either need a new constant or you must convert Nm to lb-ft.
  8. elecstudent
    Nov 11, 2010
    26
    thanks this was really appreciated, as my calulator in build conversion can't handle this, I only realised.
    cheers
