I believe this is a safety requirement as well.Connecting both primary and secondary to a ground common does not negate isolation (excepting above). It only adds a common reference point.
I agree, though let's get more specific - as I understand it the idea is that primary hot and neutral are both isolated from the chassis and ground while the ground is connected to the secondary neutral and chassis.As long as we are talking ground, and not neutral. Ground should not be involved with the high voltage side (Hot or Neutral) of the transformer in any way.
Yes, you are correct. Only the source is grounded, so your primary side, being a load for it's source, is not grounded. Your secondary, being a new source, is grounded.I agree, though let's get more specific - as I understand it the idea is that primary hot and neutral are both isolated from the chassis and ground while the ground is connected to the secondary neutral and chassis.
Thread starter | Similar threads | Forum | Replies | Date |
Toroidal transformer Screen connection | Power Electronics | 3 | ||
K | HF Transformer Connection Problem | Power Electronics | 12 | |
Transformer connection - basics | Power Electronics | 6 | ||
About transformer connection | General Electronics Chat | 9 | ||
I | 5 pin Transformer connection help | General Electronics Chat | 8 |
