I was reading through a quite detailed dissertation on derating transformers in an old thread, from April. and did not readily find an answer to my problem.....
We know, that a transformer, 120v primary, and a 12 volt secondary. Unloaded, the sec. will often read as high as 18 volts, which will drop down to a given voltage, based on the load you place on it.
How far can one push a normal step-down transformer in regards to available amperage.
I'm thinking that the circular-mil size of the secondary windings should indicate a limit of what it will put out for amps ?
I need 12 rectified volts to drive a cheap chinese air-mattress pump, and basic tests with its cigarette-lighter plug, indicates an approx draw of 3-4 amps....off a car battery............ 4-amp wall-warts are darn hard to find.
I have a real nice flat-pack transformer with an unladen voltage of 24 -- my pump is not likely to draw that down far enough to avoid overvolting the pump...........I would appreciate your thoughts and input on this.
__________________
__________________
