Transformer design
Discussion in 'General Electronics Chat' started by SVS, Mar 12, 2014.
  1. SVS
    Aug 16, 2012
    89
    Hi everyone,
    I have a few doubts about transformer design.
    1.How do I calculate the AL value(inductance factor) of a transformer core .[ ferrite in my case ].?
    The Al value is given in the data sheet is for a set of UI ungapped core.
    What if I have to stack 2-3 cores together?
    How will the AL value differ?
    2. Number of turns calculation:
    step up voltage from 300 V (square wave ) to 5.7 KV (sinuous ) rms .
    So my ratio N1:N2 is 1:19
    N1= (Vin× T/2)/ (B*Amin)
    Vin=300V.
    I max = 4 A
    f=30 KHz . T = 3.3*10^-5
    B = 0.5 T (Given in data sheet)
    Amin= 1800 mm^2
    So the value computed from this formula is my number of primary windings or the minimun number of primary windings?
    How could I calculate the number of primary windings ?
    I have also attached the datasheet of the ferrite core..
    Thank you ..
