Hi guys,
I have need to add a few AC adapters before a load.
ASCII art example
|----240v--------|AC adapters|----------------|Load|--------|
240v is the AC mains supply. 35A max
I know that the AC adapter will have a voltage drop(I * R), which will reduce the voltage supplied to the load. How can I design this connection/the adapters in a way which will result in the minimum voltage drop across the adapters but yet able to squeeze enough power from it?
ASCII art example
