Transformer Design
Discussion in 'Homework Help' started by assassin, Dec 28, 2008.
  1. assassin
    Dec 27, 2008
    20
    Hi.. i have design a inverter circuit 12Vdc / 220 Vac 20W... i'm doing it in a simu program (Pspice) but i cant get the signal from output.. i need the inductance formula of transformer.. could u send me the formula pls? if there is something wrong in my design pls say it too.. circuit is this;
  2. mik3
    Feb 4, 2008
    4,846
    63
    Flip Q3 vertically and connect a 1K resistor between its collector and the base of Q4.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Here are two links :
    one from epanorama :
    http://www.epanorama.net/documents/components/transformers.html
    And one from electricianeducation :
    http://www.electricianeducation.com/theory/electric_transformers.htm
    They are talking abou the inductance of a transformer.
    Greetings,
    Bertus
    PS here is hoe i found the links :
    http://nl.altavista.com/web/results...la&aqo=&aqn=&kgs=1&kls=0&dt=tmperiod&d2=0&dfr[d]=1&dfr[m]=1&dfr[y]=1980&dto[d]=28&dto[m]=12&dto[y]=2008&filetype=&rc=dmn&swd=&lh=&nbq=10&stq=10
  4. assassin
    Dec 27, 2008
    20
    thank you i did it but still i dont know what i write to primary and secondary number...
  5. assassin
    Dec 27, 2008
    20
    i have found a formula that is;
    L = N^2 * μ * A / l
    L = Inductance of coil in Henrys
    N = Number of turns in wire coil
    μ = Permeability of core material
    A = Area of coil in square meters
    l = Average length of coil in meters
    i calculate the primary and secondary inductance with this formula and write it to simu program but still it isnt working.. what am i going to do right now i have no idea... pls help me :(
  6. assassin
    Dec 27, 2008
    20
    Could anybody verify this formula?
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    I can't help a bit with the PSPICE, but the relationship of inductors to transformers is slim. They don't model that way. The addition of the second coil tightly coupled to the first changes its whole character.
