i'm having trouble locating a transformer that suites the needs of my project. where can i get a 1500 VA 110V to 3.5kV set up transformer?
Search for companies and ask them if they can manufacture one for you. Some companies may be able to manufacture it but it will be expensive because it will be just for you. Another solution is to combine two transformers (or maybe more) to achieve your requirements. Of course you have to take care of the power factor of each transformer as to calculate the proper power rating of each of them. By combining transformers will cost you on efficiency but you will make your job.i'm having trouble locating a transformer that suites the needs of my project. where can i get a 1500 VA 110V to 3.5kV set up transformer?
