Transformer Connections
Discussion in 'The Projects Forum' started by williamthomas, Aug 20, 2013.
  1. williamthomas
    Jul 26, 2013
    17
    Hi...
    I'm building a power amplieir. I want to connect my power transformer with two bridge rectifiers so that the output will be 2 x +- 24 volt. how should the transformers wires and bridge rectifiers be connected?
      File size:
      21.6 KB
      38
  2. Ramussons
    May 3, 2013
    562
    92
    As Shown. You need 2 of these.
    Transformer White & Blue is One set of AC input
    . . . . . . . . . Yellow & Green is the Second set of AC input
    Ramesh
  3. williamthomas
    Jul 26, 2013
    17
    what about if i want a common ground for them?
  4. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    If separate AC secondaries, the DC commons can be connected.
    Max.
  5. williamthomas
    Jul 26, 2013
    17
    you can see the attached diagram in thread nr 1.
  6. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    I just mentioned in case someone tried it with windings in common.
    Max.
  7. Johann
    Nov 27, 2006
    190
    30
    Yes, like Ramussons suggested, make two circuits like that and connect the dc sides of the rectifiers in series, i.e. negative of top rectifier connects to positive of bottom rectifier. This becomes the common or 0V rail. The top rectifier's positive becomes your positive rail and the bottom rectifier's negative becomes your negative rail.
  8. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    I took it to be Commons connected/referenced together not in series?
    Max.
  9. williamthomas
    Jul 26, 2013
    17
    then i still have two of each wires left..
  10. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Try this:
    (FYI: It's not a guess)
  11. Ramussons
    May 3, 2013
    562
    92
    The 2 wires are Orange and Orange, which, as per your post, are 230 V AC.
    Ramesh
  12. JoeJester
    Apr 26, 2005
    3,394
    1,213
    I took that to mean two +/- 24V supplies.
  13. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    That was my take also?
    With the intention of making both -ve's common?
    Max.
  14. Johann
    Nov 27, 2006
    190
    30
    Check out your bridge: 2 cathodes = Pos. out and 2 anodes = Neg. out.
    ErnieM likes this.
  15. JoeJester
    Apr 26, 2005
    3,394
    1,213
    As far as being two +/- 24V supplies, that's not going to happen with two 18 volt secunder coils in the illustrated transformer. You can get one. You can however, get two +/- 9 volt supplies.
  16. shortbus
    Sep 30, 2009
    4,092
    1,673
    Doesn't the secondary voltage times 1.41 minus two diode drops still apply to this circuit? 18 X 1.41 - 1.4 = 23.98 Isn't that close enough for government work?:D
  17. JoeJester
    Apr 26, 2005
    3,394
    1,213
    It is under most circumstances. But I took it as the OP wanted two + and - supplies. If they wanted one + supply and one - supply, that might be "close enough" depending on the load and the current rating of the transformer.
    shortbus likes this.
  18. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Thanks Johann, serves me right for not double checking an image I got off teh interwebs.
    This is what I meant. Really. Note the dots on the secondaries, that's important. Colors same as the original (I just couldn't fit them at 5 o'clock in the morning).
    I'll be quiet now.
