Transformer circuit quistion
Discussion in 'Homework Help' started by TheSpArK505, Oct 18, 2014.
  1. TheSpArK505
    Sep 25, 2013
    92
    Hi everyone .
    To answer a question u need to understand it 100%...and that's what I'm going for .
    I have a question about transformers...and it says:
    The transformer secondary is connected to an electrical load , and it delivers its rated current at rated voltage and 0.85 pf lagging , find primary voltage ?
    Can any one explain please : what does rated means , and is the power of the load is only due to secondary voltage and as nothing to do with the primary voltage ...and also the underlined part please ??:confused::confused:
  2. MrChips
    Oct 2, 2009
    12,652
    3,460
    Can you please post the complete question and not just part of the question?
  3. Kermit2
    Feb 5, 2010
    3,854
    968
    transformers 'transform' the voltage, current from one side to the other.
    The power input = the power output theoretically.
    Real world we know there are losses.
    The 'power factor' is one of the corrections we apply to determine real world conditions
    In the real world power in is ALWAYS more than power out.
    Rated levels are given in a piece of equipments specs.
    12 V 25 VA transformer(watts)
    operates from 110 VAC
    So you plug the numerical values found there into your calculations.
  4. TheSpArK505
    Sep 25, 2013
    92
    the question says that a 50 KVA , 2400/240 V, 60 Hz before mentioning any load .....Where does the 50 KVA come from ?
  5. studiot
    Nov 9, 2007
    5,005
    515
    And did you miss the lecture that explained VA ?
    Also known as VARs or Volt-amps reactive.
  6. crutschow
    Mar 14, 2008
    13,511
    3,385
    VA is volt-amps which is just the product of the volts and amps that the transformer is rated for. It is the phasor (phase vector) sum of the real and reactive power.
  7. The Electrician
    Oct 9, 2007
    2,301
    339
    Volt-amps (VA) are not the same as volt-amps reactive (VAR).
  8. studiot
    Nov 9, 2007
    5,005
    515
    You are quite right I misspoke in haste.
    The proper story is explained here very well.
    http://en.wikipedia.org/wiki/AC_power
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  10. TheSpArK505
    Sep 25, 2013
    92
    Thanks guts......some of u miss understood me ...my question that there is no load.....where does the 50 KVA come from?
    also..does the KVA = Vp,rated*Ip,rated=Vs,rated*Is,rated
  11. crutschow
    Mar 14, 2008
    13,511
    3,385
    The 50 KVA is the transformer maximum rating. That actual KVA depends upon the load. If there is no load the KVA is essentially zero.
  12. TheSpArK505
    Sep 25, 2013
    92
    OK ...But is it true that KVA = (Vp*Ip)both rated=(Vs*Is)both rated
  13. crutschow
    Mar 14, 2008
    13,511
    3,385
    Neglecting the small transformer losses, yes.
