Hello everyone, in my physics class we are starting to do a generator project.
So far my basic setup was to include a step up transformer so I can store it in high voltage capacitors, and I was going to do the diamond diode setup so that you get lumpy dc current as the output. I have heard however that with ac power and a transformer you can make it output three sine waves that are all slightly out of phase, and THEN you can inverse the bottom. This would increase the amplitude and make it lumpy DC...and if I did that instead of just using the four diodes to make it lumpy then I would increase the voltage a LOT.
I know this is possible I just may be using the wrong words I would be happy to draw a vague idea if I'm not making any sense, but do any of you have any ideas as to what I could do?
I'd be allowed to use IC's and anything else really.
