The attached image is a representation of a circuit I set up to evaluate the power output of a transformer. In the image, the transformer is represented by an AC signal (I used LTSpice for the illustration). R1 and R2 represent a pot rated at 3A. R3 is a load resistor. The circuit initialized with "R1" at 0 ohms (pot turned all the way to "off") and the source started at about 23V. The illustration represents the state where turning the pot to increase voltage across the load, R3, resulted in a drop at the source of approximately 1.5V. It is from this static state from which I did my calculations. Please let me know if there is any fault with my setup.
Solving for I:
First, R1 and R3 in parallel equals a combined resistance of 24.4Ω (1/R = 1/R1 + 1/R3)
R1 and R3 in parallel: 1.22V/24.4Ω = .05A
Voltage of R2 = Vsource - Vr1 => 21.5V - 1.22V = 20.28
I of r2 = 20.28V/500Ω = .04A
Itotal = .05A + .04A = .09A
Pot resistances were determined by measurement afterwards.
So, is that a reasonable approach to evaluating the suitability of an unknown transformer for use in a project?
Solving for I:
