Transfer Ratios
Discussion in 'Homework Help' started by pmt, Jan 23, 2006.
  1. pmt
    Jan 23, 2006
    Using a two-poert model of BJT's, I need to explain the modelling therof. I also need to do mathematical definitions, specifically about forward and reverse transfer ratios.
  2. chesart1
    Jan 23, 2006
    269
  3. chesart1
    Jan 23, 2006
    269
    There are two small signal BJT two port models: the four h-parameter small signal model and the hybrid-pi model. Although I don't have the details before me, I believe there is a low frequency and high frequency version of each. Which model are you working with and what is your progress thus far?
    John
