If it is a permanent magnet DC motor (the only kind I have tested), the RPM's (proportional to your omega) will be linearly proportional to applied voltage IF THERE IS NO FRICTION. Friction will tend to make the curve tend toward being more flat at higher voltages.
Kv is the torque constant (this is equal to Ke if done in SI units.)
J is the polar moment of inertia of the motor/load.
L is the armature inductance
R is the armature resistance
In steady state, yes the speed is directly proportional to applied armature voltage; this is not the case for dynamic situations as both the back emf and armature currents cross couple to form a more complex relationship as described above.
**NOTE** This ignores viscous damping and mechanical loss, which can typically be neglected for small machines (as I assume you are dealing with)
B the viscous damping term due to the shaft coupling is included in the euqation you ahve given, however after doing a little litmus test, I do not believe the equation you have given is correct. As stated before, the equation i gave neglects damping caused by windup in the coupler. If you remove the B you are left with:
K/ ( (Ls +R) sJ +K^2)
so, if we multiply through we get
K/ ( J*L*s^2 + J*R*s +K^2 )
Then if J*L is pulled out on the denominator we get
K/J*L * 1/( s^2+R/L*s + K^2/(J*L))
After doing this algebra, it appears that your transfer function is incorrect. The DC gain you should get (regardless of characteristic polynomial, ac gain) you should get 1/K...this is not the case. There may have been an algebraic error in the transfer function you propose...Another way to look at this is that K is in units of V/rad/s. Since the AC gain is technically dimensionless in this form having a gain of K does not make sense, SOO, yoou are then saying
omega/v [rad/s / Volt ] = K [ Volt/ rad/s * AC GAIN [dimensionless]
It is clear that rad/s / Volt != Volt / rad/s...
Again, I do not think you need the viscous damping term for reasonable results. The transfer function i have given is correct. The one you have provided has some algebraic problems likely.
Thank you for your reply. The transfer function i posted earlier was found on a journal here- http://www.waset.org/journals/waset/v32/v32-57.pdf. I would be glad if you can go through it and explain better. Thank you very much
