transfer function in SPICE
Discussion in 'Programmer's Corner' started by shin, Dec 4, 2008.
  1. shin
    Oct 16, 2006
    16
    Is it possible to get the transfer function expression of the output voltage/input voltage of a circuit in SPICE? For example, I build a passive low pass filter circuit then I want the coefficient values of s of the transfer function in the output file. What command should i use?
    One more thing, is there any output file (text file) in Multisim like output file in SPICE?:confused:
  2. mik3
    Feb 4, 2008
    4,846
    63
    Yes, after you make the simulation spice opens a new window. In the new window's tool bar there an option 'trace', as I remember, click on it and then choose input and output voltages.
