transfer function help
Discussion in 'Homework Help' started by jstrike21, Nov 11, 2009.
  1. jstrike21
    Sep 24, 2009
    104
    I got Vo/Vi= R/(R1+Ls+R)
    Vi is on the left and Vo is on the right
    My question is: At what frequency will the magnitude of H(jw) be maximum?
    I know at low frequencies it will be maximum but is that what i put for my answer?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Your transfer function is correct.
    At any frequency greater than ω=0, the output is less than that at ω=0. So ω=0 would my answer.
  3. jstrike21
    Sep 24, 2009
    104
    when finding corner(cut off) frequency do I take
    R/(R1+R),, which is the max value of H(jw), divided by square root of 2 and set that all equal to the transfer function?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    I would think the corner frequency is ω=(R+R1)/L rads/sec
  5. jstrike21
    Sep 24, 2009
    104
    now I have the same circuit but the is a capacitor instead of an inductor.
    Vo/Vi=R/(R1+(1/jw)+R)
    2.) What frequency will the magnitude of H(jw) be maximum?
    As frequency goes to infinity?
    3.) What is the maximum value of the magnitude H(jw)
    R/(R1+R)?
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Vo/Vi=\frac{R}{R1+\frac{1}{j\omega C}+R}
    2. Yes
    3. Yes
