No - incorrect. Every input terminal, whether + or - will be at Vo/2.So for each + terminal of each op amp, the voltage is Vo/2, and for each negative terminal, the voltage will be a 0? Is that correct?
Yes, I am referring to the same point you named Va.Alright. So you said Va = Vo/2. Are you referring to the top left node?
Thread starter | Similar threads | Forum | Replies | Date |
Calculate the transfer function of an OPAMP circuit | Analog & Mixed-Signal Design | 13 | ||
V | Realization of Op amp circuit from Transfer function | Homework Help | 1 | |
J | Zero in RC block | Homework Help | 20 | |
Transfer function of a cascaded op-amp circuit | General Electronics Chat | 8 | ||
Convert Transfer Function to Circuit | Homework Help | 16 |
by Jake Hertz
by Aaron Carman
by Jake Hertz
by Aaron Carman
