Transfer Function for a negative feedback loop
Discussion in 'Math' started by smarch, Nov 20, 2010.
  1. smarch
    Thread Starter Active Member
    Mar 14, 2009
    52
    Hi guys would appreciate the help.
    I am having trouble with this question.
    From the JPEG I have a attached:
    Determine the equivalent T.F. G(s) in form of G(s) = \frac{p}{qs+r}, where p, q, r are constants.
    I have tried working it out, but got into a mess. Help please, how do you do it?
      File size:
      9.7 KB
      35
  2. guitarguy12387
    Apr 10, 2008
    359
    12
    Can ya post your work?
    In general, for a closed loop system, you have:
    TF = (direct path gain)/(1 - sum of loop gain)
    From there it is just algebra to get into the right form
  3. smarch
    Mar 14, 2009
    52
    I come to :
    C(s) = R(s).(10/3s - 5) - C(s)(40/3s - 20)
    Am I on the right track?
    I have limited notes on this and have tried to follow it as they are in the notes, but it is quite a different problem to that one.
  4. guitarguy12387
    Apr 10, 2008
    359
    12
    Yeah that looks about right i think.
    Now just solve for C(s)/R(s)
  5. smarch
    Mar 14, 2009
    52
    How do you complete it all the way through to get G(s) = \frac{p}{qs+r}
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    First read here:http://en.wikipedia.org/wiki/Control_theory in the section Closed Loop Tranfer Funtion. In your case you have C=5, P=\frac{2}{3s}-1 and F=-4;
    Try to calculate the Transfer Function H(s).
    Post it and we will discuss more.
  7. krishna chaitanya
    Nov 8, 2010
    5
    TF = (direct path gain)/(1 - sum of loop gain)..
    it will give ans for this...
