Transconductance in Transistors
Discussion in 'General Electronics Chat' started by lkgan, Jan 16, 2010.
  1. lkgan
    Dec 18, 2009
    117
    Hi everyone,
    Why bipolar transistors have fewer nonlinearity problems compared to JFET? It's a fact that JFET has a lower transconductance than a BJT for the same current. How would the transconductance, gm affects the stability of a transistor? And how would the temperature variations affect the transconductance?
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    A transistor is almost always used with negative feedback to reduce its very high distortion. It has a high transconductance so reducing its gain with negative feedback still results in plenty of gain.
    A FET also causes high distortion but its transconductance is low so not much negative feedback can be used to reduce its distortion. So its distortion will be higher than a transistor.
  3. lkgan
    Dec 18, 2009
    117
    Do you know what's the relationship between temperature variations and transconductance in a transistor? In what way can I know whether a BJT is more stable compared to JFET?
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    gm for BJT is equal:
    gm=1/re without external emitter degeneration resistor (Re=0).
    And with external emitter degeneration resistor gm=1/(re+Re)
    And re=Vt/Ic when
    Ic- collector current
    Vt- thermal voltage
    Vt=(K•T)/q
    K-Boltzmann constant k =1,3804•10^-23J/°K
    q - elementary charge q =1,6021•10^-19C
    T- absolute temperature in kelvin.
    So Vt=(K/q)•T=86.1619uV•T
    And for example now we can easy calculate Vt that for 25 ° C, ie T = 298.15 K
    Vt=86.17uV•298.15K=25.691mV but for practical calculation we assume Vt=26mV
    And gm for JFET for Rs=0Ω
    gm=\frac{2*I_{DSS}}{|V_{gs(off)}|}*(1-\frac{Vgs}{V_{gs(off)}})=\frac{2*I_{DSS}}{|V_{gs(off)}|}*\sqr{\frac{Id}{I_{DSS}}
    And with external Rs resistor
    gm_z = 1/( 1/gm+Rs )=gm/(1+gm•Rs)
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    If you bias a Jfet at a certain current then its transconductance does not change when the temperature changes.
