Tran switches
Discussion in 'General Electronics Chat' started by DexterMccoy, Mar 25, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    Transistors as switches
    How does Q2 work? it's collector is grounded and the base has -13 volts
    What kind of transistor switch is this? it's like a comparator
    The resistance on the base is the negative threshold voltage?
  2. DexterMccoy
    Feb 19, 2014
    429
    Here is the schematic
  3. DexterMccoy
    Feb 19, 2014
    429
    Pull up transistor switch ( Sources current & voltage )
    pull down transistor switch ( sinks current & voltage )
    Here is the schematic drawings
  4. wmodavis
    Oct 23, 2010
    737
    150
    Schematics are much easier to read when right side up.
    shortbus likes this.
  5. DexterMccoy
    Feb 19, 2014
    429
    What kind of transistor switches is Q3 and Q4?
    Since the emitter has +15
    and the collector has -15
  6. wmodavis
    Oct 23, 2010
    737
    150
    They are PNP transistors.
  7. DexterMccoy
    Feb 19, 2014
    429
    No I mean what kind of ""SWITCH"" IS IT , since it has -15 on the collector and +15 on the emitter
  8. wmodavis
    Oct 23, 2010
    737
    150
    Sir. I cannot read your mind. If you want an answer to the question you want answered. Your question was "What kind of transistor switches is Q3 and Q4?" I answered that question. They are PNPs.
    Your new question - what kind of ""SWITCH"" IS IT. It is a PNP transistor switch biased properly as such.
  9. DexterMccoy
    Feb 19, 2014
    429
    Biased for what?
    How is it different then a PNP transistor switch that is Unbiased?
    What does a PNP transistor switch that is Biased do different VS a transistor switch that isn't Biased?
    i don't understand the difference or advantage of a transistor switch that is Biased VS unbiased
  10. DexterMccoy
    Feb 19, 2014
    429
    These transistor switches have a Bias or threshold voltage on the Bias
    It seems that the transistors switches will only turn ON when it exceeds the Bias voltage
    Take a look at the +Vcc and - Vcc on the Bases of the Transistor switches
    Q1 is a SHUNT switch
    Q2 is what kind of switch? it doesn't shunt or short out the signal to ground, so what is it called?
  11. DexterMccoy
    Feb 19, 2014
    429
    How does this transistor Q6 transistor switch work?
    here is the schematic
  12. GopherT
    Nov 23, 2012
    6,297
    4,019
    Hahahahaha!
    Circularity!
  13. DexterMccoy
    Feb 19, 2014
    429
    I mean it's not a shunt switch, so how do the transistor switch function or work?
Thread Status:
