Tramsistor Question
Mazaag
Joined Oct 23, 2004
255
Hey guys,
Newbie here..
Just a quick question..
On this circuit Diagram, what is the purpose of the 1K ohm resistor connected underneath the 3K ohm resistor next to the base of the transistor?
don't you just require a current to enter the base, and it will switch the collector on ? ( ie : can't you just have it connecting straight from the 3kohm resistor to the base ? without the 1 k ohm ? )
thanks guys
http://skyscraper.fortunecity.com/plug/587/learn97.htm
vhneumann
Joined Dec 1, 2004
Originally posted by Mazaag@Dec 1 2004, 03:26 PM
Hey guys,
Newbie here..
thanks guys
[post=3892]Quoted post[/post]​
Even when the output of the comparator goes low the voltage at the transistor's base it is not 0V because of Icbo (leakage current from collector to base). This current causes a voltage to appear across the base-emitter junction, causing greater current through collector. Build the circuit, leave the 1K resistor open and you will see the LED dimly lit when the ouput from the comparator is 0V. Connecting 1K resistor in place lowers the impedance seen from the base; Vbe gets lower and Ic reaches cutoff (Icbo is still there). The same circuit applies if you use a MOSFET, though the physics are different.
Best regards
Mazaag
Joined Oct 23, 2004
255
Wouldn't we fix the problem if we put a much higher resistor instead of the 3k ohm ? I mean woudln't that lower the current into the base , and there make the LED dimmer ?
beenthere
Joined Apr 20, 2004
15,819
A higher value resistor just makes the problem worse. Transistors are current amplifiers. The beta, or Hfe figure gives the potential amplification of the transistor. Limiting current into the base also affects the current through the collector circuit, and dims the led. And without the other resistor to ground, the leakage problem is still there, so the led never goes out.
