trafo power rating
Discussion in 'Homework Help' started by zack, Jun 19, 2004.
  1. zack
    Jun 9, 2004
    Just a simple question, why do some transformer power rating are specified in Watts and others in VA power?
    Zack
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Hi Zack,
    Great question. I always thought that since W(watts) = E(volts) X I(amps), that it was only some peculiararity of electricians that caused them to want to use volt-amps instead of watts. Unless someone can shed some light, I think there's no difference in the measurements.
  3. mozikluv
    Jan 22, 2004
    1,437
    hi,
    i believe the purpose of using watt to rate a transformer is to inform the user that he can only connect loads up to the rate they say. if they say 500w then you can only connect circuits that require up to 500w only. if your device needs 1000w then surely your transfo will not be able to supply and gets overloaded.
    VA = Power output / efficiency
    VA = 500w / 0.9 * 0.9
    VA = 617
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The terminology Volt-Amps (VA) refers to the complex power rating, which is expressed in the form:
    S = P +jQ
    Where P is your active power in Watts (W) and Q is your reactive power in Volt-Amps-reactive (VAr).
    We also know S as the Apparent Power which has great significance with AC 3-phase electrical systems.
    Obviously for DC systems S = P (because Q = 0).
