traffic light help using 555 timers
Discussion in 'The Projects Forum' started by miketest, Feb 15, 2014.
  1. miketest
    Nov 9, 2012
    12
    Ok, so my project is to make 2 traffic lights with different timings on their own using 3 555 timers... the idea is to use the first 555 timers output as the source for the other two timers.
    the problem is that when I calculate for the resistor values, the timing for the circuit gets messed up. I looked into it and saw that the problem comes from the initial charging towards 1/3Vs for the capacitors... i could calculate it in, however for succeeding cycles, this charging cycle is no longer done..
    so my question is that how would you design a circuit so that the capacitors never go below 1/3 Vs..
    tl;dr the initial charging time of the cap from 0 to 1/3 Vs is messing with my timing because its not really present in net cycles, is there anyway to work around that problem or can i even have a vary the frequency and duty cycle automatically
  2. Kermit2
    Feb 5, 2010
    3,847
    963
  3. xainnasir
    Nov 8, 2012
    26
    You sould check this one out ..... They have implemented the complete traffic light project using 555 timer and it will be quitegood for others who want to work on this project, they have also provided the download link for proteus simulation as well. Here's the link to download it: http://www.theengineeringprojects.c...-control-using-555-timer-in-proteus-isis.html
    I know its an old thread but it will help others.
