Traffic light design
Discussion in 'Homework Help' started by The Rocketeer, Feb 17, 2011.
  1. The Rocketeer
    Oct 20, 2010
    7
    Hello guys,
    I have to make a project about traffic light design but I couldn't know how to start with. Can you help me out with your ideas? you will find the instructions attached below as pdf.
    Thank you~~~~~​
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That's a pretty comprehensive guide to the design. Are you familiar with logic? It kinda sounds like a design to be made with gates rather than a microprocessor.
    The best place to start one of these is with a flow chart.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    My advice is to use a microcontroller if you are allowed to. It will make your life so much easier. I have done something similar, less complex, but actually built it too.
    http://forum.allaboutcircuits.com/showthread.php?t=43588
    It still needs a lot of upkeep. Breaks down every month or so. I have found that it is more important to build strong than build complex.
