Your diagram is correct, but the 74LS190 is missing VCC and GND pins in the diagram, so if the program you're using to simulate it automatically provides voltage to that chip then there might be an option to set what voltage it sees.
I'll post a diagram shortly, I'm going to try the diagram using the 555 timer circuit as it's setup in your diagram.
