Hello everyone!
This is my first post over here. The program code I made is that of a traffic light control system and it is not working properly, the way it is supposed to work.
The question statement is as below:
And the program I have so far is this:
It doesnt work on Proteus, the traffic lights do not go on and off with the one second delay, and my display function on a 2 digit seven segment, doesnt show anything. The interrupts and the keypad dont work either. I am not very good at assembly and in detecting errors, especially the logical ones so I would greatly appreciate it if someone could help.
Thanks.
You have to implement an intelligent traffic control system using 89C52/8051 µcontroller, which operates on the basis that how many cars are present on the road.
The roads are served in clock wise fashion (north, east, south and west). During normal load on road, traffic signal remains green for 30seconds.
An entry from the key pad (4*3) determines the load(0-99) on that road. There are also 2 switches connected for selecting a road. (00ànorth, 01àeast, 10àsouth, 11àwest).
There is also a switch which a pedestrian can press at any moment and that roads signal goes red [so the person can pass]. Handle the situation intelligently.
You have to decide the time of each road on basis of its load, if its above normal then you have to give more time for green light and vice versa. Handle the situation intelligently.
The time counter is also displayed on 7-segement displays.
Rich (BB code):
org 000h
ljmp main
org 0003h; external interrupt subroutine - P3.2
ljmp ext0
org 0013h
ljmp ext1
;MAIN
org 0030h
main:
clr P2.4
clr P2.5
clr P2.6
clr P2.7
MOv TMOD, #11h; timer 1, mode 1 -16bit, timer 0 mode 1
mov ie, #10000101b
setb tcon.0; to set edge level interrupt
setb tcon.2
main2:
north:
setb p1.4; 1.4= north; 1=green, 0=red
clr p1.5
clr p1.6
clr p1.7
JB p2.4, north_manual
jnb P2.4, normal1
normal1:
mov R2, #30
lcall counter
east:
setb p1.5
clr p1.4
clr p1.6
clr p1.7
jb p2.5, east_manual
jnb p2.5, normal2
normal2:
mov R2, #30
lcall counter
south:
setb p1.6
clr p1.4
clr p1.5
clr p1.7
jb p2.6, south_manual
jnb p2.6, normal3
normal3:
mov R2, #30
lcall counter
west:
setb p1.7
clr p1.4
clr p1.5
clr p1.6
jb p2.7, east_manual
jnb p2.7, normal4
normal4:
mov R2, #30
lcall counter
sjmp main2
RET
north_manual:
mov b, r3
mov R2, b
lcall counter
RET
east_manual:
mov b, r4
mov R2, b
lcall counter
RET
south_manual:
mov b, r5
mov R2, b
lcall counter
RET
west_manual:
mov b, r6
mov R2, b
lcall counter
RET
; Subroutine for keypad
KEYPAD:
mov P2,#00000111b; convert the first three pins to input
K1: mov P1, #00h
mov A, P2
anl A, #00000111b
cjne A, #00000111b, K1
K2: lcall delay
mov A, P2
anl A, #00000111b
cjne A, #00000111b, over
sjmp K2
over: lcall delay
mov A, P2
anl A, #00000111b
cjne A, #00000111b, over1
sjmp K2
over1: setb p1.0; ground row 0
mov A, P2
anl a, #00000111b
cjne A, #00000111b, Row_0
setb p1.1; ground row 1
mov A, P2
anl a, #00000111b
cjne A, #00000111b, Row_1
setb p1.2; ground row 2
mov A, P2
anl a, #00000111b
cjne A, #00000111b, Row_2
setb p1.3; ground row 3
mov P1, #11110111b
mov A, P2
anl a, #00000111b
cjne A, #00000111b, Row_3
ljmp K2
Row_0: mov DPTR, #CODE0
sjmp find
Row_1: mov DPTR, #CODE1
sjmp find
Row_2: mov DPTR, #CODE2
sjmp find
Row_3: mov DPTR, #CODE3
sjmp find
find: rrc A
jnc match
inc dptr
sjmp find
match: clr A
movc A, @A+dptr
; traffic db 0; traffic=variable to store traffic
ljmp K1
org 0400h
code0: DB '0', '1', '2'
code1: DB '4', '5', '6'
code2: DB '7', '8', '9'
code3: DB '#', '0', '*'
RET
;CounterandKeypad
traffic:
acall keypad
subb A, #30
mov B, #10
mul AB
mov R1, A
acall keypad
subb A, #30
add A, R1
mov R2, A; saving a copy of A
RET
counter:
back7: mov A, R2; R2 contains traffic, average=30
mov B, #10
div AB
mov R1, A; save a copy of A
mov A, B
mov DPTR, #temp
movc A, @A+DPTR
clr p0.7 ; p0.7 and p2.3 --> selection lines
setb p2.3; select 1st Led, common cathode selection
mov P0, A
ljmp shortDelay
mov A, R1; reload A for second digit
movc A, @A+DPTR
setb p0.7; second led
clr p2.3
mov P0, A
lcall delayOneSec
djnz R2, back7
temp: DB 3Fh, 06h, 5Bh, 4Fh, 66h, 6D, 7Dh, 07h, 7Fh, 67h; hex codes for 0-9
RET
;for External Interrupt
ext0:
;Subroutine for Selecting Roads
select:
jb p3.4, label1
jnb p3.4, label2
label1: jb p3.5, label3; for 3
jnb p3.5, label; for 2
label2: jb p3.5, labelE1
jnb p3.5, labelN0
labelE1:; for east
acall traffic
setb p2.5; bit to indicate that a manual traffic has been entered
mov r4,A
labelN0:; for north
lcall traffic
setb p2.4
mov R3,A
label3:; for west
lcall traffic
setb p2.6
mov r6, A
label:; for south
lcall traffic
setb p2.7
mov R6, A
reti
ext1:
jb p0.0 ,n_p ;program if interrupt was called when noth's green light was on
jb p0.1,e_p ;east
jb p0.3,w_p ;west
jb p0.2,s_p
n_p:
clr p1.4
clr p1.5
clr p1.6
clr p1.7
mov R1, #30
lcall counter
ljmp north
e_p:
clr p1.4
clr p1.5
clr p1.6
clr p1.7
mov R1, #30
lcall counter
ljmp east
w_p:
clr p1.4
clr p1.5
clr p1.6
clr p1.7
mov R1, #30
lcall counter
ljmp west
s_p:
clr p1.4
clr p1.5
clr p1.6
clr p1.7
mov R1, 30
lcall counter
ljmp south
reti
delayOneSec:
mov r7,#14
rept1:
mov tl1,#00h
mov th1,#00h
setb tr1
again:
jnb tf1,again
clr tf1
clr tr1
djnz r7,rept1
;ret
/*mov TMOD, 01h; Timer 0, mode 1- 16 bit
mov TL0,#00h
mov TH0,#00h
setb TR0
here:jnb TF0,here
djnz R4, back2 */
RET
delay: ;Delay for 20ms
mov tl0,#0B7h
mov th0,#0FEh
setb TR0
again1: JNB TF0, again1
clr TR0
clr TF0
RET
ShortDelay: ; delay for 2.5ms
mov R7, #9
here9:mov R6, #255
here2:DJNZ R0, here2
here3:DJNZ R7, here9
RET
END
Thanks.
