Hi, I am looking for a circuit for a variable dual tracking power supply that can supply 0 to about 18 v dc at max. 1 amp. The purpose is to play around with some op-amps etc. The idea is that one pot (dual I suppose) controles the voltage. I will probably fit two volt meters and an amp meter as monitoring.
Thank you
R
Thank you
R
