Yes- this is my general idea. I can place the ranging components in a longer 'dead' section of tube to avoid the minimum detection range imposed by the sonar technique,So is the plan for the 4kHz technique to output a series of short bursts of 4kHz and the measure the return time of the echo?
Suck 'em instead of blow 'em? Seems fine, but what's the advantage?....all tubes connected to neg. pressure manifold requiring less pressure then pos. pressure.
Rather like the reflection from an unterminated electrical transmission line....................
Using my signal generator and scope, I can experiment with different burst lengths and frequencies. It's interesting to see how strong the reflection is even just pinging the open tube end, the open end reflects a pulse almost as strong as when I cap it with a hard surface, but with phase shifted by about 90 degrees, which makes sense. ....................
by Jake Hertz
by Jake Hertz
