TR-2
Discussion in 'The Projects Forum' started by milbecker1, Jan 16, 2013.
  1. milbecker1
    Jan 14, 2013
    Being a musician,I have a Simple question,I have a Boss TR-2 Tremolo pedal
    The switch started working intermittently and has the effect on all of the time. Seems its a simple single pole that turns the effect on and off.
    anyone know where I can get a replacement sw. after looking at it and a wiring dia. I see it just switches to ground.
    This is my first post,I'm an electrician with little knowledge of electronics. Thanks
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    Is the switch actually bad or maybe the wiring/solder has come loose due to the repeated cycling/use.
    Gonna have to open it up and get us a picture and any numbers you find on the switch itself... I doubt there is a bill of materials floating around showing the exact manufacturer/part number of the switch.
  3. GopherT
    Nov 23, 2012
    6,319
    4,044
