We may be guessing for some time to come - http://www.ecnmag.com/News/2010/03/Toyota-black-box-data/
One other source I have seen indicates that Toyota USA has exactly one portable computer that can read out their black box codes. Toyota is hardly likely to let such data get published.if they can prove Toyota knew about the sudden acceleration problem at the time
this is true. there are now 120 on order for april. toyota says they simply havent had time to roll out more black box readers to the state- while all the other car companies have had free and open access to their black boxes for almost a decade now. its a little hard to argue that toyota has been covering this up massively... theyre a japanese company anyway, its not surprising to me.One other source I have seen indicates that Toyota USA has exactly one portable computer that can read out their black box codes. Toyota is hardly likely to let such data get published.
This story has also reached Europa. In the discussion a person said that on a Toyota Prius. Both the transmission system and the motor start/stop system are electronic controlled. So you can not put the gearbox in "N" then the accelerator is operated, or the car is rolling. And the same will apply to the stop button as prius has a engine start and stop button. Is this true?Some question is being raised as to whether that incident might have been a stunt. The man had the presence of mind to use his cell phone, call 911, and talk with the troopers, but not to turn off the engine or shift into neutral (both actions have been recommended by Toyota).
I am sure there will be more to follow.
John
According to an American news report, "After the car decelerated to about 50 mph, Sikes turned off the engine and coasted to a halt."This story has also reached Europa. In the discussion a person said that on a Toyota Prius. Both the transmission system and the motor start/stop system are electronic controlled. So you can not put the gearbox in "N" then the accelerator is operated, or the car is rolling. And the same will apply to the stop button as prius has a engine start and stop button. Is this true?
So like many computers, a press of the power button does nothing until you have gone to shut down, unless you hold it for a few seconds.You have to hold the engine off button for 4 - 10 seconds and it will kill the engine.
I think the problem is more complex than saying all Toyota cars are a hazard to all other motorists on the highway, and that they should be parked in the garage.Not only are these Toyota owners likely to be killed, but they . The Blue book has recently lowered the re-sale value of Toyota cars.
If you have a Toyota, parking it in the garage might save your life.
Regards, DPW [ Everything has limitations...and I hate limitations.]
It is beginning to sound more and more like the finger a lady found in her chili.During and after the incident, Sikes said he was using heavy pressure on his brake pedal at high speeds.
But the investigation of the vehicle, carried out jointly by safety officials from the National Highway Traffic Safety Administration and Toyota engineers, didn't find signs the brakes had been applied at full force at high speeds over a sustained period of time, the three people familiar with the investigation said.
The brakes were discolored and showed wear, but the pattern of friction suggested the driver had intermittently applied moderate pressure on the brakes, these people said, adding the investigation didn't find indicators of the heavy pressure described by Sikes.
If some agency purchases the Prius in question and drives it for testing purposes, that should tell us something. That is trying to prove a negative, though, so it may be quite difficult to make a firm determination of the lack or presence of the problem. A few thousand miles on a car having exhibited the failure should demonstrate a repeat of the runaway again, though.It is beginning to sound more and more like the finger a lady found in her chili.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Robert Keim
