Touch Sensor LED Dimmer
Discussion in 'The Projects Forum' started by osburn383, Oct 7, 2009.
  1. osburn383
    Oct 7, 2009
    Hi im trying to figuring a way to make if possible a touch sensor dimmer for a LED lamp i am make for my industrial design class. I would want it to turn on the lamp at dim and as you drag your finger across the specified area for it to brighten up to full and drag it the other way to dim and then off.
    I looked into pwm dimmer to control the leds but not sure how i would incorporate a touch switch in the design. Im assuming i could use a touch sensor circuit to replace the pot that would control the dimmer switch originally.
    Any help would be greatly appreciated
    Forums seems awesome been looking for something like this for a while to help with my projects.
    Mike
  2. JDT
    Feb 12, 2009
    658
    85
    Google QTouch (which is now part of Atmel). They do some evaluation kits.
