Touch Alarm Problems
Discussion in 'The Projects Forum' started by kazz, Jan 10, 2014.
  1. kazz
    Dec 27, 2013
    10
    Can anyone suggest or help me how to convert the circuit with one touch plate only, Using the same components? I'm still new to electronics, and i just understand a little bit on this circuits and functions of each components. BTW im using 3-9 V, is it OK ryt?
    Thanks for Suggestion/Help.
  2. Alec_t
    Sep 17, 2013
    5,967
    1,135
    I don't see any way to use a single touch plate if you can use only those components.
    Any simple circuit using a single touch plate is likely to be triggered by interference.
  3. #12
    Nov 30, 2010
    16,665
    7,310
    I've used a jfet to pick up finger hum. It would suffer from not being universally dependable as a retail product, but it might work for you. Google fet touch switch.
  4. kazz
    Dec 27, 2013
    10
    you can add any components as long it have a atleast 3 transistors,....and the easily trigerred, im trying to fix it by changing the values of the resistors near in the plates. Am i doing it right?
  5. kazz
    Dec 27, 2013
    10
    your circuit was good, thanks for it, i will try this after my project,.... .but my project neede d atleast 3 transistors
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
  7. Alec_t
    Sep 17, 2013
    5,967
    1,135
    Since this is appears to be a Homework project, we won't give you a complete solution; but consider how you would modify your circuit around T1,T2 to incorporate #12's suggestion of using a jfet (e.g. a 2N3819).
  8. kazz
    Dec 27, 2013
    10
    if im going to change T1 and T2 experimentally, it cost lots of expenses which might damage other components...and i cant try this to simulation since it needs to touch to work. What if i change the value of resistors? but i dont know which of the resistors.
  9. kazz
    Dec 27, 2013
    10
    thanks to this, but im new to electronics,...i still need to study more about on it... u have any simple/basic suggestion?
  10. MrChips
    Oct 2, 2009
    12,624
    3,451
    Yes, the simplest circuit begins with an N-FET or MOSFET as the first stage as #12 suggested.
    Bias the FET correctly and you can pick up 50/60Hz line frequency interference whenever you touch the gate.
    kazz likes this.
  11. kazz
    Dec 27, 2013
    10
    i still need to study the J-FET and MOSFET, i still dont understand its analogy
  12. MrChips
    Oct 2, 2009
    12,624
    3,451
    Actually, a FET is easier to understand than a BJT.
    A BJT is a current device. The base-emitter current controls the collector-emitter current.
    A FET is a voltage device. The gate-source voltage controls the conduction channel and hence the resistance of the channel. The gate input impedance is very high and hence is more sensitive for applications such as touch sensors.
  13. Alec_t
    Sep 17, 2013
    5,967
    1,135
    You can simulate touch, by applying a voltage (50/60Hz hum signal) via a high resistance (representing a finger).
  14. kazz
    Dec 27, 2013
    10
    what simulation can i try? with a complete components, im just using circuit wizard but lack of components like the transistors,....any good simulators that have all components in the given diagram?
  15. radiohead
    May 28, 2009
    474
    31
    Here's a circuit that uses only one touch pad. Maybe you can find a way to incorporate this with your 3 transistors that you must use.
    kazz likes this.
  16. Alec_t
    Sep 17, 2013
    5,967
    1,135
    I use LTspice; a free download from Linear Technology, with extra libraries of models freely available from the Yahoo LTspice User Group.
    kazz likes this.
  17. kazz
    Dec 27, 2013
    10
    @Alec_t, i have a question, why does the a 0.3W speaker is not producing a sound when i supply a 9volts source,....it just vibrating, but when i supply a 3V source it make sounds,.. i dont see whats the logic of the speaker,....And about the other component i try to simulate it and change it values, it seems nothing change, i cant point out whats the real purpose of each of the resistors and capacitors
    thanks for the reply
  18. kazz
    Dec 27, 2013
    10
    how can i import a transistor,...2n6107 pnp transistor model is not in the LTSpice.,
  19. #12
    Nov 30, 2010
    16,665
    7,310
    Try a 2N4403 or a 2N3906
    kazz likes this.
  20. Alec_t
    Sep 17, 2013
    5,967
    1,135
    Whether or not the circuit works seems to depend critically on component values selected, particularly on the impedance and voltage of the battery powering it.
