Total Resistor Power (W)
Discussion in 'General Electronics Chat' started by superway, Aug 30, 2016.
  1. superway
    Thread Starter Active Member
    Oct 19, 2009
    128
    Hello
    On my attachment below, there 2 drawings A and B. They are both connected in series/parallel. What is the difference between 2 drawings?
    The total resistor of each is 0.2 Ohm, but are they the same Total Power ?
    Please help
    Ken
  2. wayneh
    Sep 9, 2010
    12,396
    3,246
    In both cases, the current through each resistor is the same. So the power dissipated by each resistor is the same.
  3. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Theoretically given identical zero tollerance resistors the voltage across the extra connections is zero both ways so they are identical.
    When you factor in tollerance it gets messy since you can have a lower resistor paralleled with a higher resistor, and current will flow thru the extra connections. Not much, so generally they still work very similarly when they are still pretty close in tollerance.
    Hopefully one of the spice guys will wander by and give some solid numbers here.
  4. ronv
    Nov 12, 2008
    3,404
    1,478
    It's very possible I did it wrong, but I don't see much difference. But a little.
    Sorry the lines aren't very dark.
      File size:
      23 KB
      9
