Total resistance + Thevanin problems
Discussion in 'General Electronics Chat' started by Dritech, Nov 11, 2012.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I have some problems regarding total resistance and Thevenin.
    Problem 1:
    In the first attachment, is the 2ohms in parallel with the 6ohms, total in parallel
    with the 8ohms and the total in series with the 10ohms ??
    Problem 2:
    In the other attachments I am trying to find I load using Thevenin theorem, but the current is not matching with the correct answer. Does anyone know what am i doing wrong?
    Please help.
    Thanks in advance and sorry for my poor English.
      File size:
      13.6 KB
      26
      File size:
      292.5 KB
      34
      File size:
      297.4 KB
      29
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Problem 1:
    2Ω resistor is short by the wire.
    Problem 2
    I got the same answer as you
  3. Dritech
    Sep 21, 2011
    756
    5
    Thanks for the reply.
    Does that mean that i have to ignore the 2 ohms (i.e. 6 in parallel with 8, result in series with 10 ??
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, exactly you shoudl ignore 2Ω resistor.
    And as you said Rtot is equal Rtot = 10Ω + 6Ω||8Ω
    Dritech likes this.
  5. Dritech
    Sep 21, 2011
    756
    5
    Hi again,
    I have the attached circuit with parallel and series resistors. Are they as follow:
    12//18 --- result//10 ---- result2//22 ---- result3 + 15 ??
  6. Dritech
    Sep 21, 2011
    756
    5
    And in this circuit are the 22 + 15 .... result//18 .... result2 + 12 + 10 ???
    PLEASE HELP.
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    Resistance seen from this current source terminal is equal to
    Rtot = ((22+15)||18) + 12 + 10 = 34.109R
    And resistance seen from 48V voltage source terminal is equal to
    Rtot = 22 + 18 + 15
  8. Dritech
    Sep 21, 2011
    756
    5
    And what happen with the 12 and 10 resistors please?
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    The 48V source current can flow only in closed loop. So how can he flow via 12 and 10 where we have a open circuit?
    Dritech likes this.
  10. Dritech
    Sep 21, 2011
    756
    5
    Ok. Thanks for your fast reply :)
  11. Dritech
    Sep 21, 2011
    756
    5
    Hi again,
    can someone tell me how to work the total resistance of the attached circuit please ?
  12. Dritech
    Sep 21, 2011
    756
    5
    If I work it as below, is it correct?
    ((R1//R2)//R3) + (R4//R5)
  13. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well, between which terminals you want to find this total resistance?
    Also you can always use delta-wye transformation.
  14. Dritech
    Sep 21, 2011
    756
    5
    Hi Jony130,
    I want to find the total resistance from the terminals of the load resistor which is marked in red in the picture attached below. I removed the load resistor since i meed to find the current on each resistor using Thevenin theorem (so I think I cannot use delta to star transformation)
    Thanks in advance.
  15. Jony130
    Feb 17, 2009
    3,990
    1,115
    If so I think that Rtot = R3||(R1||R4 + R2||R5)
    Dritech likes this.
