Total noob, DPST switch question
Discussion in 'The Projects Forum' started by alexb, Jan 28, 2009.
  1. alexb
    Jan 28, 2009
    Okay, so I am working on a way to light a series of lights for my a project I am working on. here is what I am trying to do.
    the lights are meant to be attached to circuit that comes on when triggered my something else. While I want this to happen, I want to have the choice to override this and have them be always on.
    I am not familiar with a DPST switch, but from what I believe, you can have two power sources and choose between the two with a switch?
    For this case I would have the dimmer source which is not always on, and an always on source.
    So when I wanted them to be controlled by the thing that will turn them on or off, I could flip to that on the switch, or if I want them to just be on I can flip to the other part of the switch.
    Is this how this works?
    Is there a better way?
    Please help me because I am such an amateur :p
    Okay, in case that didn't make much sense, if you follow this link:
    http://www.allaboutcircuits.com/vol_4/chpt_4/1.html
    and scroll down to selector switch that is what I am talking about. It can select between two different power sources, and output to the same device( in this case the lights).
  2. Externet
    Nov 29, 2005
    775
    57
    I believe you are referring to a wrong type of switch. It may be instead a double pole double throw DPDT to select permanent on or dimmed.
  3. Farlander
    Oct 14, 2008
    158
    Here's how I would do it
