Total newbie.....PIC18f45k20 help please
Discussion in 'Embedded Systems and Microcontrollers' started by alfa777, Jan 24, 2012.
  1. alfa777
    Jan 23, 2012
    Hi I'm just a little housewife that decided to take on a challange, that of course beeing........program a pic micro controller from microchip, bought a PICkit3 with dev board, USB and PIC18f45k20 (44pin). I did some studding, and got as far as to copy and paste some code. It build successful, even program after released, but that's it nothing else. There are for sure power cause the 3 lights yellow, blue and yellow is on. but my LED does not come on. Now for my stupid Q..... how do I check it a certain pin in a certain port are link to a certain one of 8 LED's. Please help, maybe I should start from scratch. I'm coding in assembly. Any suggestions where I could get some (in laymans language) tutor material online that could help total newbies with there struggle getting started. Thank you for taking the time to read this, any help will be really appreciated.
    alfa777
  2. t06afre
    May 11, 2009
    5,939
    1,222
  3. spinnaker
    Oct 29, 2009
    5,062
    1,160
    If you bought the board then it comes with working examples. There is no need to copy or paste anything.
    You need to apply power to the MCU. That can be done through the programmer.
    In MPLab select Programmer/Settings/Power. Set for 3.25 volts.
