i have a toshiba nb205 netbook latley it has started blue screening on shutdown, and saying thes no page file on login. i have tryed to adjust the page files to userdefined and system managed both do the same thing. the BSOD code came up somthing like a usb powerstate problem, or hard drive isue. i have used thumb drives in it in any port and it will have to be pluged in it will open for a little bit then it becomes unacesible till it is repluged in again some times many times. planing on reinstalling it in a few weeks to see if that fixes it. but the usb isue has me almost thinking it could be a damaged port or somthing else on the motherboard. (i have heared of quite a few usb isues in laptops.) or it could be a virus or somthing is corupted then the reinstall should fix it. however to install it i will have to use a usb divice and if this is the problem i guess it will fail then i know what part of the isue is. i have tryed virus scans and nothing comes back as threatining. bios seemed normal time is corect no settings should afect this. it boots and runs other than these isues.
i was wondering if anyone else has had similar isues and or how i can fix it.
