Toshiba lcd tv burn out smd component
Discussion in 'General Electronics Chat' started by isaac2011, Apr 20, 2012.
  1. isaac2011
    Apr 20, 2012
    LCD TV TOSHIBA 32AV700E
    Power Inverter Board PSIV161C01T
    Hi, Greetings
    I want to know, identify burn parts smd componenet.(Power Inverter Board)
    This location is (or see picture)
    QG802 = SMD Transistor <--is look 7K mark
    RG805 = SMD Resistor
    RG806 = SMD Resistor
    RG807 = SMD Resistor
    RG808 = SMD Resistor
    DG802 = SMD Diode
  2. R!f@@
    Apr 2, 2009
    8,792
    771
    Wanna fix it.
    Have soldering skills on SMD components ?
    Know how to use a DMM?
    Gimme better focused pixs with better lighting, need to be high resolution.
    and yea.. Need the model no. too.
  3. Stevo88
    Aug 23, 2012
    It seems like a transformer burned on my board (also power supply unit
    PSIV161C01T)
    on the transformer:
    IP-32SE-VM
    LSE-B10 1026BF3K
    can you help me identify it? lead me to it's datasheet or anything that can replace it?
    It seems to get +-140v DC in the input. nothing on the output.
    Thank you.
  4. R!f@@
    Apr 2, 2009
    8,792
    771
    Do not hijack other threads. Go and open a new one in general electronics chat.
