Torque
Discussion in 'Homework Help' started by mo2015mo, Jul 23, 2013.
  1. mo2015mo
    May 9, 2013
    157
    Hi Guys,,
    how i can determine the loop's surface normal for my attached problem and for any loop?? what's the rule??
      File size:
      53.8 KB
      26
  2. WBahn
    Mar 31, 2012
    18,069
    4,905
    Draw a diagram from above so that you are looking down the edge of the plane of the loop. Then figure out the normal.
    Or, find two vectors that lie in the plane of the loop and then take the cross product, which yields a vector that is normal to both of the vectors in the plane.
    You have to decide which direction to use and for that rely on the right-hand rule.
    The obvious vectors to use are the vectors of two sides of the loop:
    v1 = z^
    v2 = sinθ x^ + cosθ y^
    By the right hand rule, if we cross v1 into v2 we will have a vector consistent with the direction of the current in the loop
    v1 x v2 = (0 - cosθ)x^ + (sinθ - 0)y^ + (0 - 0)z^
    v1 x v2 = -cosθ x^ + sinθ y^
    mo2015mo likes this.
  3. mo2015mo
    May 9, 2013
    157
    I finished the EM1 course and got A+ grade. :) :) :)
    ________WBahn________
    Thanks for all your efforts to help me get this done.
  4. WBahn
    Mar 31, 2012
    18,069
    4,905
    Congratulations. Glad I could help.
