Hi, I am new to this!
I am struggling to answer the following:
what size ( torque etc. ) 6 volt dc. planetary gear motor would I need to lift
a 3kg. load vertically.
I plan to couple the gear motor directly to a 12mm dia. steel acme lead screw
with a 3mm pitch.
The load I will attach to a brass lead screw nut.
A stainless steel guide will stop the nut rotating and so give it vertical travel.
Any better guesses out there than mine ?
Thanks all.
with a 3mm pitch.
Thanks all.
