toroidal transformer
Discussion in 'General Electronics Chat' started by misael.mata, Sep 20, 2014.
  1. misael.mata
    Aug 26, 2014
    55
    will a bad toroidal transformer cause transistors to overheat and burn in a amplifier circuit.......
  2. #12
    Nov 30, 2010
    16,705
    7,358
    It depends on what the transformer is being used for. If it's the power supply transformer, a failure will cause its voltage to fail and the associated transistors will run cooler while the transformer burns up.
    misael.mata likes this.
  3. crutschow
    Mar 14, 2008
    13,529
    3,393
    As #12 says, if it's a power transformer it's failure is quite unlikely to cause overheating and circuit failure.
  4. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    In what way do you suspect the transformer is Bad?
    Max.
  5. GopherT
    Nov 23, 2012
    6,340
    4,094
    of all things that can go bad, it is rarely the transformer putting out too much voltage - I have never seen that. Too much current draw through the transistor (to few ohms on the load) is usually the cause.
  6. misael.mata
    Aug 26, 2014
    55
    well with transformer on, the transistors get hot enough to burn my finger, and i put a multimeter on the transformer to check its resistance and iam not getting a reading. if its not the transformer than what else would cause transistors to burn up, ive checked all caps and and resistors.
  7. #12
    Nov 30, 2010
    16,705
    7,358
    Please be reasonable. We don't know whether you are working on a childs' toy or the computer that runs the Coca-Cola bottling factory in Atlanta Georgia. How are we supposed to guess what went wrong???
  8. MaxHeadRoom
    Jul 18, 2013
    10,873
    2,530
    ...And that makes little sense either?
    Max.
  9. GopherT
    Nov 23, 2012
    6,340
    4,094
    Not getting a reading as in, zero ohms or infinite ohms? Are you getting an AC voltage when your hot transformer is running? What else is getting hot? A large transistor, the output load, the rectifier diodes (diode bridge ), a section of the pcb.
  10. misael.mata
    Aug 26, 2014
    55
    okay so now i swapped out the transformer and all seems okay, the transformer had a shorted winding, thanks for the help guys, the amplifier is up and running
  11. tom_s
    Member
    Jun 27, 2014
    287
    342
    always good to see a happy ending
