Which is used for devices like tape recorders. The gaps are extra sensitive to magnetic variations.
What if the toroidal core is made off multiple pieces semicircle stuck together? how can I avoid flux leaks?Practically speaking, there are none. The magnetizing current sets up a flux in the core, but it is confined to the core. That is an advantage to using toroids - they tend to keep that magnetic flux confined. If you need poles, which are discontinuities in the magnetic core that allow the field lines to emerge, you will have to saw out a section of the torus.
It may be in the accuracy of the fit. There may be some further source with experience you can consult. And you can always try an experiment - recall that iron filings will show magnetic flux lines. A piece of paper and some filings will show problems at a joint.how can I avoid flux leaks?
why is it then that manufacturers make coil core out of many laments "sheets" of metal instead of just one solid piece? do those have flux leaks or 100% flat fit?It may be in the accuracy of the fit. There may be some further source with experience you can consult. And you can always try an experiment - recall that iron filings will show magnetic flux lines. A piece of paper and some filings will show problems at a joint.
The reason for the laminations is to cut down on eddy current losses. The eddy currents are proportional to the steel circuit thickness. In other words, each lamination has its own little eddy current. Eddy currents are like the little water eddies in a flowing river current. They are separate from the main current as eddy currents are separate from the main magnetizing current of the transformer. Eddy currents cannot be eliminated from any magnetic circuit...only minimized.why is it then that manufacturers make coil core out of many laments "sheets" of metal instead of just one solid piece? do those have flux leaks or 100% flat fit?
Thread starter | Similar threads | Forum | Replies | Date |
K | Toroidal transformer differences. | General Electronics Chat | 7 | |
Where can I buy toroidal transformers with no secondary? | General Electronics Chat | 24 | ||
Toroidal coil | General Electronics Chat | 25 | ||
P | Very Basic Question About Toroidal Coil Use | General Electronics Chat | 6 | |
Toroidal coil and magnet question | General Electronics Chat | 113 |
by Duane Benson
by Aaron Carman
by Jake Hertz
by Duane Benson
