TOPspice simulator
Discussion in 'General Electronics Chat' started by karas, Aug 25, 2016.
  1. karas
    Thread Starter Active Member
    Sep 8, 2011
    127
    Is there any big deference between topspice and LTspice, is ltspice enough or not?i am looking for good software to help me to do simulation for switch mode power supply design
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I'm not familiar with topspice, but it is all about the models. If you have the models you want to use for the simulation then either one should be fine. LTSpice is free and has a large Yahoo Support Group that you can get counsel and advice from. You could just run the experiment and tell us your results.
    karas likes this.
  3. Alec_t
    Sep 17, 2013
    5,972
    1,135
    LTspice was created primarily for SMPS design.
    karas likes this.
  4. crutschow
    Mar 14, 2008
    13,498
    3,374
    As PB noted, the main difference is likely the available models.
    Check to see if either has the models for the devices you want to use.
    karas likes this.
