As a decimal point is small & sometimes lost, some conventions use the multiplier as the decimal point so 7k5 is 7.5k.
I've been thinking of going whole hog on that schematic, drawing my own version along with a PCB.
Here are my thoughts for a flowing stream: I used the 4015 shift register, SR, because I had one, but would prefer the 74C164. for the greater output of 8 mA stretchable to maybe 12 mA. The flickering signal source is a candle LED which is connected to the data input of first SR. The signal is PWM with the pattern repeating about every 300 clock pulses. Interesting effects are noted as SR clock is varied. I would eliminate sync pulses from U3, C2 & R3-4 as not needed. I envision 4 SR's with 3 blue LED's in series for 96 LED's or 5 SR's for 120.
If I were building this , the SRs would be distributed along the stream, connected dead bug style with semi wire wrap.
On breadboard, red LEDs were only ones that were available ( 8 )View attachment 99047 & are quite visible with only 1 mA.
On board layouts I sometimes use copper tape for long & short runs. Some from stained glass store now maybe TapeMaster.com.
On using dead bug wiring, be sure to keep a chart of part no.s and orientations, as when glued top down all information is lost.
ok cool.. 12v is my supply voltage. Hey do you use Eagle Cad?Don't see a power supply voltage. What are you planning on using? I suspect 7.5Kohms is too large. I'm in the middle of drawing mine.
I did not do a careful analysis, but at first glance yours looks good.
Here is what I have come up with so far...
The NPN are 2N2222A or similar, the MOSFETs are 2N7000. I have never build Bernard's circuit, but if you use 12VDC then the current through the transistor will be around 14ma max. This is probably good enough for your application.
I designed for 10ma using the current limiter on U4, but it can be bumped up a lot by changing R3. I haven't built this one either, but I probably will get around to it.
The max count for the light chaser can be set using the diode AND gate made by CR1 and CR2. If you do not use this AND gate ground the inputs, else it will not work.
I use PCB Express, and make my own boards.
.How I make PCBs
.How I make PCBs
It is funny, I bought all the parts and did a lot of the cutting work, but never finished this project, which definitely applies.
It is a test display for a PIC or similar. This is similar enough.
Re Long Chaser 7k5 is a little large, 3k9 would be about right.
Stream, the more I see the LED's dance the more that I like it. Use 74C164 for direct drive of blue LED's with R6-14 = 180 ohms; the
4015 output listed as 8/10 mA.
Thread starter | Similar threads | Forum | Replies | Date |
G | Light flashing unit for car | General Electronics Chat | 133 | |
C | Push button flashing light circuit | Digital Design | 58 | |
Flashing protocol for stm32 | Microcontrollers | 1 | ||
Dyson dc01 hairdryer. 3 red flashing lights then stops working. | Technical Repair | 11 | ||
R | difference between: push-pull & flyback topo | General Electronics Chat | 2 |
by Aaron Carman
by Duane Benson
by Jake Hertz
by Jake Hertz
