Topic Gone?
Discussion in 'Feedback and Suggestions' started by Hurdy, Feb 28, 2006.
  1. Hurdy
    Thread Starter Senior Member
    Feb 27, 2006
    137
    Why can I no longer view any topics in the Project Forum? I was abile to view it this morning.
    I have some information on there that I need and it says something about the cut off age.
    Any ideas??
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    I assume it is an oldish thread. If you go to the bottom of the Projects Forum page you will see a selection box saying "From: 30 days" - click the down-arrow to the right of it and select "Show all". The Projects Forum will now show all threads posted in that forum. If you have any further problems let me know.
    It will also move this to the Off-Topic Lounge where it is better suited.
    Dave
  3. Hurdy
    Feb 27, 2006
    137
    I've tried that. The post was only made early hours of this morning.
    If I do as you say the latest post is 2005.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Hi Hurdy,
    I have noticed that the same thing is happening here. Can you tell me which web browser you are using? (just to eliminate that as a possibility).
    Dave
  5. Hurdy
    Feb 27, 2006
    137
    Internet Explorer v 6.0.2900.2180
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Thanks I have tried it with IE6, Mozilla Firefox and Opera, and all browsers are having a problem.
    I have contacted the site administration about the problem and will relay any information I get back to you. Apologies for the problems.
    One thing I can suggest is do a Google search for your topic title and confine the search to the allaboutcircuits.com domain - Google will give you the option of viewing a cached paged when the actual page is not available. At least this way you can view the topic you require, obviously assuming Google has a cached copy of the page. However its is worth a shot.
    Dave
  7. Hurdy
    Feb 27, 2006
    137
    Thank you Dave I will give it a try.
    Do you think the information lost here will be recoverable? I imagine its all in a database somewhere?
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    At this point I can't say. The site admin are based in the US and may not be alerted to this problem for a good few hours. As soon as I know what the situation is I will let you know.
    Incidently, I have just tried the Google cached option on an arbitrary thread from the Projects Forum and it works; so you should have at least something to keep you going till this problem is resolved. Again I can only apologise for the present problems and hopefully we'll be back up and running soon.
    Dave
  9. Hurdy
    Feb 27, 2006
    137
    Nope no luck with google :(
    Well I can't find mine.
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    I assume that is because Google hasn't cached the page yet. It was worth a try.
    I can only say try back later when hopefully we will have more information about the situation.
    Dave
  11. Hurdy
    Feb 27, 2006
    137
    Ok thanks dave you've been a big help.
    I've got to go to class now :p and learn some exciting Analogue about Phasor's. Sounds exciting doesn't it :p.
    Speak to you later.
    Thanks again,
    Rob
  12. Hurdy
    Feb 27, 2006
    137
    Any news?
  13. Hurdy
    Feb 27, 2006
    137
    Does windows cache pages I have previously viewed? Is it still possible to view previous pages even when I have restarted?
  14. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Hi Hurdy,
    Apologies for the delay getting back to you. As of yet there is no response from the AAC site admin about the forum being down. I will endeavour to contact them again about the issue.
    You are using Internet Explorer which does cache the web pages you view. The following works for Windows XP, let me know if you have a different OS.
    1) Open My Computer
    2) Click Tools>Folder Options>View
    3) Check Hidden files and Folders>Show hidden files and folders
    4) Close Folder Options
    5) Navigate to C:\Documents and Settings\<your name>\Local Settings\Temporary Internet Files\
    Assuming you have the standard Windows XP install this folder will have all the web pages you have visited recently (certainly over the last week depending on the folder size), you will need to sift through all the .html/.htm documents in there to try and find what you are looking for. It is a labourious task but will probably work (that is assuming you don't have IE set to empty this folder on exit).
    Hope it goes well.
    Dave
  15. n9352527
    Oct 14, 2005
    1,198
    The browser caches the pages, try looking at the browsing history. The browser is usually set to delete caches after a certain time interval.
  16. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    IIRC in IE6 the temporary internet files are limited only be the size of the folder, however the browser history (which is a log of the visited web pages) is retained for a time period in days set from the Internet Properties>General tab.
    Either way, assuming default IE settings, a recent visit to a web page will be resident in both the browser history and the temporary Internet files folder.
    Dave
  17. windoze killa
    Feb 23, 2006
    605
    24
    I also can't see any of the posts in the project folder so I doubt very much it has anything to do with browser cacheing. I am guessing the server has had a big hiccup.
  18. Hurdy
    Feb 27, 2006
    137
    Ok ive found all my cached pages. But they will to access the net. Seeming the page is no longer available online the html page I try to open directs me to the page saying its no longer available.
  19. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I am also unable to view any topics in the Projects folder. Says "No topics were found. This is either because there are no topics in this forum, or the topics are older than the current age cut-off."
    When I set the date filter to "show all," 9 topics from 2004-05 come up - although there seem to be 87 pages (86 of which are presumably empty...)
    Could the server have experienced a glitch?
  20. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Its not a case of there being a problem with browser caching, my advice is for Hurdy to try and get cached version of the web pages so that he can see the reply to his topic. It does on the face of it appear that the problem is a server-side glitch somewhere.
    I personally haven't had a response from the AAC admin regarding this issue, so I will chase them up again and try to get someone to look at it.
    In the meantime it appears as though forum members can post new topics in the Projects forum.
    Any news I get I will relay here.
    Dave
