tool for punching a db9 and db25 hole on panel
Discussion in 'General Electronics Chat' started by vijaybala85, Jul 2, 2010.
  1. vijaybala85
    Jan 7, 2010
    92
    Does anyone know of such a tool to punch a hole onto the panel?
    VJ
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Yes, and they can be quite expensive. How many holes do you need punched? If it is only one or two, then a scribe, drill or scroll saw/coping saw to rough out -- a nibbler also works --, Dremel with carbide burr, and file will work fine.
    John
  3. lightingman
    Apr 19, 2007
    374
    22
    I know that Qmax do a tool for the 25 way 'D' connector, as I have one. As for the 9 way, I made a tool that I use on the fly press.
    Daniel.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. BMorse
    Sep 26, 2009
    2,675
    234
    here you go >> http://www.mcmaster.com/#knockout-punches/=7sfb3o
    but as others had said, a drill motor, drill bit/s, and some jeweler files is all you would need really to make a one time hole....
    as these are the only tools I used to make the holes below on an XBox360 console...
    B. Morse
  6. Dx3
    Member
    Jun 19, 2010
    87
    7
    I guess this is a good example of the laws of supply and demand. If db9 and db25 connectors were used a lot, say, on every one of the millions of personal computers sold in the last 20 years, the punches to make the mounting holes would be cheap, like $5 each. Right?
  7. KL7AJ
    Nov 4, 2008
    2,047
    295
    Yes, GREENLEE makes them; I have a 9 pin one right in my hand here. Alas, it's not mine, however....as they're quite expensive. If you plan on doing a LOT of this, it might be worth the investment...but otherwise, you''re best off borrowing one.
    Eric
  8. vijaybala85
    Jan 7, 2010
    92
    Thank you all for your help. I really appreciate it. Esp the pictures. :()
    I think I will have to go with the cheaper option because the circuits I have design are cheaper than the knock out punches. Maybe I will just replace the db9 connectors with something more rectangular and right angled.
    V
